Old 02-03-2022, 10:07 AM
gkingbing gkingbing is offline
Default Rattling noise, 1541, Magnum, Dual Hydro
This machine has had a noise that is between a rattle and knocking noise while running for some time. It sounds more like its from under the seat that ahead towards the engine. It runs well and is used regularly for plowing and is retired to storage during the summer months. I am hoping that it will continue to function until spring when I can do some troubleshooting. We are currently getting another winter storm (2/3/22) and will need it to plow. Has anyone experienced this and what was done to correct it? Thanks for any feedback.
Old 02-03-2022, 12:38 PM
I believe I would pull the cover and take a look. Might be something
coming loose with your driveline. Could be a simple fix unless it blows
up while you are plowing. Then you could be down fixing lots of stuff.
Good luck and check back with what you find.
Ken
Old 02-03-2022, 02:29 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Since that family of engines is pressure lubrication, I would see what the oil pressure is using a hand held mechanical gauge. The oil pressure port is on the right (as you are sitting on it) side front of the block. Cold PSI should be 50-60 psi. Hot at 3650 RPM 40-45 PSI using 30 Weight oil
Old 02-06-2022, 01:24 PM
1811woody's Avatar
Very possible its your drive shaft check for play."Cub Cadet 1541 (141-652-100) - Cub Cadet Garden Tractor (SN: 816509 - 821059) Drive Line Parts Lookup with Diagrams | PartsTree" https://www.partstree.com/models/154...drive-line-13/
Old 02-08-2022, 11:16 AM
Default Rattle fix
Thank you for the responses. I pulled the tunnel cover and nothing is obvious in there...I will run it with the cover off and use a plastic hose to listen and try to determine where the noise is coming from.....From observing the drive breakdown I can see where this may challenge my abilities...
Old 02-08-2022, 01:00 PM
Don't underestimate your abilities, the drive line is pretty simple once you study some on it.
Old 02-08-2022, 03:48 PM
Remove the side panels one at a time and see if it stops rattling, no?, remove the grill, no? remove the headlight panel, no? remove the hood, no? remove the gas tank, then it will stop rattlin"
Up to 534 and counting...
Old 02-08-2022, 05:40 PM
Ha,LOL good one
Old 02-09-2022, 02:16 PM
Default Great idea
I really like the gas tank removal idea....It sounds like the easiest solution. I did listen with a tube when it started rattling yesterday and could not pinpoint the source...I mechanic friend stopped by and I could not get the %*@#@ thing to rattle...All I did was grease a fitting on the shaft that I didn't previously know was there...Couldnt reach the front fitting. It only ever started rattling when its warmed up and after moving several snow banks yesterday I couldnt get it to rattle.....Oh well...will wait and see what it does after the next snow storm.
Old 02-09-2022, 02:17 PM
There is just a slight amount of play in the shaft.
