Old 05-06-2022, 11:46 AM
TheSaturnV's Avatar
Might try putting it up on jack stands, supporting only from the frame. Then just go around to to see what jiggles.
Old 05-07-2022, 03:46 PM
crazykilik crazykilik is offline
I was able to replace the bolts that were missing on the rear frame. I also found one missing on the front of the frame. I’m still experiencing a vibration. I’ll have to live with the vibration For now.
Old 05-07-2022, 04:17 PM
I would suspect the issue is in the Drive Line. The Drive Shaft, Couplers, or Flex Discs, could be slightly off.
Since this is a NF tractor, might have to jack the tractor up, get underneath and have a look.
Old 05-08-2022, 04:03 PM
I put the TracVack back on. I recently took it off when I changed the transmission fluid. Not sure how long it was on there. Previous owner is dead. Most of the vibration is gone.
File Type: jpg 4577A48F-FCB7-4793-8ED0-03E24A552139.jpg (14.6 KB, 60 views)
Old 05-10-2022, 06:39 PM
Well the 127 is now leaking transmission fluid. Assuming the vibration damaged something. I’m going to part ways with it. A bit beyond my skill set to fix. If someone wants the tractor it is free to a good home. I’m in New Franklin OH.
Old 05-11-2022, 12:51 PM
I found the leak. Something on the drive shaft cut a hole in the top of the transmission filter. Not sure how the frame piece above the shaft comes off? I’ve taken every bolt off I can but it’s not moving. I’ll attach a picture of the piece I’m talking about.
File Type: jpg 7F27CFFA-20A9-4F0A-B5DF-E16B8520A0CC.jpg (26.6 KB, 31 views)
Old 05-11-2022, 02:45 PM
Chad126's Avatar
Chad126 Chad126 is offline
No way man! I don't know what your knowledge or skill set is, but it is NOT beyond your skill set. If you want to fix it, there is a ridiculous amount of knowledge here. Post pics, symptoms, results, etc and you can get it fixed if you would like. Not trying to talk you into anything, but you can definitely do this if you want to.
9 years ago I bought a 1992 Buick Century and it started running hot with a bad head gasket. I came to work and asked if anyone knew a good shop. An older gentlemen asked me what engine it had, then he told me that if I took good pictures and brought them to him each day, he would walk me through changing the head gasket. 7 days later it was done, and ran great until I sold it.
You can do this man.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 05-11-2022, 03:02 PM
Thanks man! From the link you posted it looks like I have to take the dashboard and steering wheel off along with the rest of the top half of the tractor before I’ll have access. Any tips or suggestions are appreciated.
Old 05-11-2022, 03:43 PM
That piece DOES NOT come off!
It's a welded integral part of the frame.
The only thing that could have made a hole in the top of the filter is something on top of it coming loose such as the spirol pin or bolt that someone put in place of it working its way out.
I suspect that may be the source of your vibration as well.
Loose and wallowed out spirol pin holes on the driveline coupler.
You may need to split the tractor to resolve these issues.
Removing the steering wheel and dash will be a futile effort at best and will not gain you much at all.
Old 05-11-2022, 03:52 PM
Okay man. I’m not sure what you mean when you say “split the tractor”. How does one split a tractor? Appreciated
