Still working on my friend's 149. Thanks for all the help I have received so far. The tractor moves smoothly when going from neutral to forward. When going to reverse, it is sorta jerky and moves in reverse too quickly. Goes too fast too quick. Hydro fluid has been changed with travellers premium and new NAPA filter 1410. Took the relief valves from my 149 and put in tractor being worked on. Nothing changed. Any help will be greatly appreciated. Thanks and have a great day.
Bob |
I'd take a look at the linkage from the dash all the way to the trunnion shaft. I'm gonna bet something is worn.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Thanks for the reply's. I can't see anything extremely worn on the linkage. Nothing jumps out but being over 50 years old I am sure all the linkage is worn. Going to adjust the brakes, find and lock in true neutral and then adjust linkage. Hopefully that will help and not make it worse. Going to try to work on it today. Will let you know how it turns out. Thanks and have a great day.
Bob |
