Old 05-31-2022, 10:37 PM
WisCC WisCC is offline
Default Moving a Hydro when it's not running
How much can you push a hydro tractor around before damaging the transaxle? I have CC129 and the owners manual says to hold the relief lever up while moving it by hand. I have the lever but it don't seem to make any difference, up or not, in how the tractor moves. It moves easily with the brake off. Honestly there are times when just pushing it makes the most sense. Not looking at towing, just at those times where a good shove is easier than starting it and moving under it's own steam.
THX!
Old 06-01-2022, 07:03 AM
Take a look see at the top of the transmission where the valves are located.
A PO may have swapped out the manual valves for auto's
Either that or you are missing the release plate that actuates the manuals when depressed via the lever.
Old 06-01-2022, 07:17 AM
First, welcome to OCC..........
You can safely move a Cub Cadet Tractor with a Hydro Transmission. The early model had manual Relief Valves, that a lever needed to be lifted up to release internal pressure, before the move could be done. Later models, had automatic Relief Valves, where once the motor stopped, the internal pressure was released. Note, that a lot of the older manual Relief Valves were updated to the newer automatic type, regardless of tractor age.
Either way, once the internal pressure was gone, one could move the tractor with out issue. Moving the tractor for a mile, at 25 MPH, would be a "no-no".
Old 06-01-2022, 07:59 AM
As far as "moving" a hydro, rule of the thumb is: at a toddler speed and about as far.
the " inners" of a hydro, are sort of like an egg,
you can chase it around in a bowl and it still looks like an egg. but get rowdy with it, and 'yall have an omelet
Old 06-01-2022, 09:41 AM
Cubcadet_107's Avatar
I still keep these pictures of the old hydro pump off my 107. This is what can happen if you tow or roll your machine too fast. And this was a relatively tame failure, sometimes they break through the aluminum case!
That being said, don't be afraid to push it around. If you do it slowly and carefully you won't damage anything. They are designed to be pushed around like this.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 06-02-2022, 10:26 PM
Thanks for the info! Neighbors will appreciate me not having to light this thing off before I go to work.
