Old 09-27-2022, 09:39 PM
mschel72 mschel72 is offline
Default Trying to choose 105 vs 125
Hi, I just purchased a 105 and a 125 with the intent of using one for snow blowing and some other utility work. The other will either be used for parts or maybe another future project. It was a package deal that included some other cool stuff as well.
Anyway, is there any specific $$ value or differences that would lean to one vs the other?
The 105 runs but has some charging issue and also low on power. The motor was supposedly rebuilt a bit ago but supposedly has some points issue.
The 125 does not run and is in much worse cosmetic shape. It supposedly needs points and a carb rebuild. It has the headlights option which is neat.
Initially I was leaning towards the 125 since it has a k301 (?) 12hp vs the 10hp.
I believe they are both narrow frames but did they change anything to accommodate the 12hp motor?
I just got them home so have not had a chance to mess with them yet. Just trying to focus my initial efforts on one vs the other.
Still new to these old cubs but slowly learning
Thanks.
Old 09-27-2022, 10:08 PM
Same tractor, same series
one is a 10HP and the other a 12hp
Whichever trips your trigger
Old 09-27-2022, 11:17 PM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Given the choice, I always go with the larger horsepower. But that's just me....
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 09-28-2022, 07:30 AM
Same tractor, same series. One is a 10HP and the other a 12HP.
I second that.
Old 09-28-2022, 01:47 PM
mortten mortten is offline
Especially for snow work.
Doug
QA-36A
42" blade
Old 09-28-2022, 07:56 PM
Tom Dowling Tom Dowling is offline
Keep them both, get them both running. If you can afford both then you don't have to decide anything.
Old 09-28-2022, 09:41 PM
Thanks all. I didn't want to invest in one vs the other if one was more rare or valuable. I think I am going to invest in the usual new battery, carb clean/rebuilt, plugs and see how they both go.
I had a bit of time today to mess with the 105 since it was the closest to running. Cleaned the sediment bowl and ran some carb cleaner through the carb. It starts with a fresh battery but amp meter shows D(ischarge) vs C(harge). The day I picked it up we had to either jump it to keep running or run a fresh battery.
Previous owner said it had points issues, is there a minimum voltage where the points/magneto(?) or other ignition parts will cut out? I know I need to trace the charging issue but the cutting off is odd to me. I am more familiar with slightly more modern ignitions (duraspark, hei etc).
The VR looks to be shiny so probably pretty new and the wiring to it is pretty new too.
I found some wiring diagrams on the site so will trace with that too.
thanks.
