Old 09-30-2022, 06:07 PM
Rex B Rex B is offline
Is the end of your input shaft threaded? If it is run a bolt in it, use a jamb nut and use a socket adapter in your drill to spin it CCW.
The shaft end is not threaded. It is fine splined, too fine to grip a 12-pt socket.
I could probably fab something to drive it using the adapter that bolts to the flywheel, but I'll try the other methods first.
Old 10-01-2022, 01:17 PM
Originally Posted by Rex B View Post
That makes sense. I tried that early on, but my lack of conviction stopped me before I applied much pressure. I like that better than cracking hoses.
I'll give that a shot tomorrow AM.
If that doesn't work I'll crack the lines.
Thanks for the help!
Well that worked! (Where's that hat-tip emoji?) Thanks!
