Old 12-28-2010, 09:05 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Default Narrow Frame Hyd. Lift
I have a NF hydraulic lift that needs to be rebuilt. Its all there, just needs to be gone thru. Is there a rebuild kit available for these units?
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 12-29-2010, 02:14 PM
oldironlindy's Avatar
oldironlindy oldironlindy is offline
I do not think so. I wish there was I have a couple on the shelf that need a rebuild.
Soo many Cubs Soo little time...
Current collection: Orig. (2) 70's, 100, 71, 72, 73, 86, 108, 128, 169, 800, 1650, 1811, (those are the keepers for now) Kwickway loader, Haban Mower, #2 yard cart, IH box blade, IH york rake, IH back blade, Donnell Fork Lift attachment, Planet JR. two row planter, many brinley attachments, and of course tillers, decks, blowers and push blades.
Would like to find a Viking seeder, Gannon eartcavator, other unusual attachments, and 9 speed Original.
Old 12-29-2010, 04:07 PM
nickvanorman
Guest
Posts: n/a
im sure there are other parts that will fit them. hoses and fittings and seals and stuff. i have one and i want to put new Hoses and fittings on it. since someone painted over the hoses WHICH I HATE WHEN PEOPLE DO THAT. the paint cracks and looks horrible.
Old 12-29-2010, 04:13 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
I wish there was I have one I want to go thru before I install it!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 12-29-2010, 05:03 PM
nickvanorman-
If the paint isn't too old, lacquer thinner will probably remove it from the hoses.
Old 12-29-2010, 05:16 PM
IHinIN IHinIN is offline
I fixed one for Mrcubcadet that was leaking around the shaft behind the pulley. There are only a couple of seals in the pump to replace. There's 1 on the shaft just behind the pulley and another on the spool that is a square o-ring but a regular round 0-ring will work. He got the seals from the Cub Cadet dealer so I don't know the part numbers.
Old 12-29-2010, 07:00 PM
mrcubcadet's Avatar
I may still have have the part numbers, I will check.
-105___ Tiller
Old 12-30-2010, 04:27 PM
mrcubcadet's Avatar
Ok, the Cub Cadet dealer had to run the input seal off of a Wheel Horse. The number is 5959
The next two are O rings (I think), both are IH numbers. One is 238-5114, the other is, 238-5222.
Hope this helps,
-105___ Tiller
Old 06-29-2011, 11:32 PM
litlmikeyl's Avatar
Default Pump & Cyl. Mounting Pieces
Thanks for all of the help guys, but I have come to another problem. I'm missing the plate & dowel pin that the cylinder attaches to on the pump mount and my main mount that attaches the pump "U"-shaped bracket to the tractors' frame is all goofed up thanks to the PO's torch fixes and additions. Can any of you give me dimensions for the pieces I pointed to with the red arrows in the picture attached so I can make some new brackets?
I apologize if the picture is of your tractor... Google was nice enough to find it for me a while back and it works great for description purposes here.
Mike - Ramsey, MN
'65 100 - #126432
Old 07-02-2011, 10:33 PM
Carolina Cubber's Avatar
Carolina Cubber Carolina Cubber is offline
Send me your email and i will send you a zipfile that cover rebuilding the NF hydraulic pump and cylinder. suprasport@triad.rr.com
