Old 07-02-2023, 10:25 AM
Club Cadet Club Cadet is offline
Default 20A slow blow fuse
Is there an alternative to CC part # 925-3120? I blew the 20A fuse mowing the other night. I replaced it with a regular 15A I had laying around to finish the yard. Its still a mystery as to why it blew in the first place. Id like to replace it with the right fuse but for $5 each CC I could buy a whole pack somewhere else.
Old 07-02-2023, 07:05 PM
Go to the Auto Parts Store(s) and pick up a 3AG type 20A Slow Blow fuse. Might even find it at Wally World.
Old 07-04-2023, 07:30 AM
Thank you!
"3AG" seems to be what I was missing in my google searching. "20A slow blow" fuse was bring up ceramic fuses for microwaves and stuff. I've come to learn "AG" = automotive glass. Sometimes you just don't know what you don't know.
Old 07-04-2023, 01:54 PM
Farmall450's Avatar
Originally Posted by Club Cadet View Post
Thank you!
Who would have guessed
Old 11-29-2025, 12:25 PM
jfinney's Avatar
jfinney jfinney is offline
Thank you to all of you that have offered help. I have gotten very busy at work and around the home and last weekend was finally able to pull the engine and tighten the starter back up. Also, after checking the wiring on just about the entire tractor, I flipped the seat up and found a one inch section of insulation that was rubbed off of the positive wire coming off of the battery. Squared that away and now everything works well again. Thanks again for all of your help. Now to get the snow plow on this weekend. Snow is coming next week
