I just wasted an hour in the backyard trying with no luck to get my QA-42 onto my 149 tractor. It's been in storage for about a decade, but I know it fit on there back in 2013.
I can't get the lower bar into quick connect jaws at the same time as the upper forks slide onto the frame studs. I sure did make a mess of my frame's paint job though. I even tried some 4x4 wood blocks under the blower housing.
1973 Cub Cadet 149 2023 John Deere X590 Farmall B sitting in relative's barn |
Eat your Wheaties, have a handy list of expletives ready........ Some remove the blower unit and driveshaft first. Next, install the frame/gearbox assembly to the chassis. Double check all of your connections and make the quick attach is locked. Reassemble the blower and driveshaft. Tip....replace the set screw in driveshaft when finished. Good luck!
Queen Of The Quietlines!
That's a good idea- I didn't think to remove the blower housing first. I need to replace the carriage bolts and hardware that's holding the gear box plate, etc. I'll give that a try when I'm ready to attempt the job again.
Found this operator's-instalation manual in the tech section under implements:
https://s3.us-east-2.amazonaws.com/c...wer+Op+Man.pdf It usually takes me 5-10 minutes to instal snow thrower on my 149.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
![]() ![]() ![]() '76 1200 Dad bought '75 1200 "Twinsie" per my daughter |
If we are talking about getting the Blower bracket mounted to the tractor, I found an easy way to do that was to disconnect the springs that support the blower, that allowed me to install the belt support the bracket, pivoting it to install all the bolts. Having the bracket securely fastened to the tractor I could not lift the blower to reattach the springs, then connect the rod to the handle to raise and lower the blower.
Now I have a question: I went to replace the drive belt on my CW 36 snowblower, it is mounted on a 1967 model 72. the belt had a chunk missing so I did not want to risk it breaking in the middle plowing my driveway; it looked like a 28" x 1/4" belt but I figured I would let the pros look up the size; they said I needed a 28 x 3/8 belt, which I bought and attempted to install, it was too small. I exchanged it for a 29 x 3/8; which was too big. I called the pro back and he told me a 28 x 3/8 is the correct belt.... any thought or experiences on this would be much appreciated Joe |
The 28 x 3/8 IH-487043-R1 is correct. Do you have a manual to install it?
Have you ever tried 2 mover's dollies, one on each end of the snow thrower. Allows you to easily wheel it up to the front of the cub. If it is too high up, try wedges under the front tires to help adjust it to the right height.
