Old 05-25-2024, 07:31 PM
bean1974 bean1974 is offline
Default 1641 steering gear
i have 10 in of freeplay left and right.any fixes available
tks guys
Old 05-26-2024, 09:40 AM
10" is a lot, you may have a broken steering shaft.
Old 05-26-2024, 01:05 PM
i mow my yard my arms a like jello when im done
Old 05-26-2024, 05:37 PM
Default steering gear
it still turns right and left but at least 8 in of free play
Old 05-27-2024, 08:14 AM
johnwd98 johnwd98 is offline
you're not providing enough info to get any help. You may have to get on your hands and knees and wiggle the steering wheel back and forth to find any obvious signs of wear. For starters, the sector may be worn and need adjustment or parts replaced, the drag link ends may be worn, the tie rod ends may be worn, the spindles may be worn, the pivot pin for the axle may be worn. You could also need to check toe-in, just to name a few.
Old 05-27-2024, 09:29 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
If it is the column here's a thread in the Tech section that may help. I replaced the rod ends then bearings and pin in the gear box on my 1641 a few years ago. It made a big difference. https://www.onlycubcadets.net/forum/...ead.php?t=4631
Cannon
Old 05-27-2024, 09:55 AM
Check your E-Mail, I sent you the service manual for the Cyclops series tractors and mower decks.
