The bearing in the PTO on my 1440 went bad, so I ordered a used PTO off eBay. I put it on, and went to test it and it worked for about 30 seconds then stopped like I shut off the switch. Now with the tractor off, I can hear it click when I flip the switch, but the PTO does not engage with the tractor running. I adjusted the air gap to .017. The PO bypassed the original PTO switch and added another one. Just a simple on off switch with power coming from the battery, so no safety switches. It has worked fine like this for the 2 years I’ve had this tractor so I don’t think that’s the problem. It is getting 12 volts at the pto, and it is grounded. Did I get a bad PTO or what? I can send it back and get a different one, but want some opinions first.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
If you have 12 volts at the PTO and it doesn't engage I'd say it's bad.
https://www.google.com/search?client...1-d&q=917-3389 I've had good luck with these PTO's https://xtremeope.com/p/xtreme-repla...det-717-3389p/
If it will help any, recheck your connections at the PTO. While you mentioned you have 12v at the PTO and it is grounded, sometimes the contact/connection points might be compromised (example: dirty, paint on connection surface, etc.) that it's enough to render the PTO inoperable even if it worked for a moment.
Otherwise, just like others say, return the PTO for replacement.5
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
It was a bad PTO. My new one came in and I put it on and it worked perfectly. I put about 5 hours on it over the weekend with no issues. And the best part, this one was actually $15 cheaper than the first one.
Glad all is well and you let us know.
Thanks George. I hate it when someone asks a question and never comes back to post the outcome.
