Old 06-25-2025, 02:25 PM
Blute Blute is offline
Default 125 hydro wont move
I just removed and replaced the hydro fluid and filter on my 72 125. Now it does not move! I used a fram PF-16 for the filter, is that the problem??
Old 06-25-2025, 05:23 PM
Grandpa53 Grandpa53 is offline
PH2844 is the correct Fram replacement.
Old 06-25-2025, 05:36 PM
ironman's Avatar
ironman ironman is offline
I don't know about a Fram PF-16, but I use Fram PH16's and have no problems.
Old 06-25-2025, 07:08 PM
IHCubCadet147's Avatar
I would definitely get the correct filter on it, even if that’s not the problem. Also, what kind of fluid did you use? IH Hytran is recommend. Sometimes they need to be primed after changing the fluid. I have seen it recommended on here before to wrap a rag around the end of an air hose, and give it a quick shot in the fill hole to help get the fluid where it needs to go.
Also, it has nothing to do with your problem, but your 125 is not a 1972, they were made from 1967-1969.
Old 06-25-2025, 07:59 PM
Default Primed
Thanks for the Info. Just got the 125, trying to restore it! Rebuilt the engine replaced the mechanical clutch,What a pain, Thought I had all the bugs worked out, last thing to do, R@R the hydro system. Easy, Right, Now it doesn't move off the Lift! Would die for an easy fix on this one!!!
Old 06-25-2025, 08:04 PM
P.S. I used TSC"s replacement for HI-TRAN
Old 06-26-2025, 08:32 AM
More then once I have thrown myself for a loop on a 125. The hydro
wouldn't work because I had the lever to disengage it engaged.
I figure I might be the only one to do such a thing, but.
Since we are looking for an easy fix.
Ken
Old 06-26-2025, 09:09 AM
ironman's Avatar
I too use TSC hydro fluid. Never a problem.
But just curious, you say tractor is on a lift,
so why wouldn't you pull the rear cover to see what lurks in there???
And besides, you didn't say if it ever moved before you did anything
so HTF do we know if it's a new problem or a 40 year old problem???
Old 06-26-2025, 09:27 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Don't forget to undo the relief valves if they have been manually pressed in...
Or, if you have never had the tractor running and going circles before this oil change, it's possible youncould have a sheared or missing pin in the driveshaft.
My crystal ball is kinda fading
Plow blade
#2 Cart
QA36 snowthower
Old 06-27-2025, 08:17 AM
DSarow DSarow is offline
We need a bit more info,when did the tractor run correctly in all its functions.I envy you have a lift,you can do a lot more visual and easier maintenance than this old part crawling around on the concrete.Seriously I doubt it's your fluid,try your old filter or a different recommended brand on the list.Switch valves like Digger said.Just don't let trashy grass clippings get in.The Hydro System is pretty bulletproof, give it another careful inspection,report back to our readers,they will put their thinking caps on and help you.
And the sponsors,on the top of the page,deserve a chance to help out!Just saying!!
Tags
125 hydro problems
