Old 09-05-2025, 10:41 AM
CubCadet107-129 CubCadet107-129 is offline
Default 42 Inch Snow Blade to Cub Cadet 107 to 129
Hello, Only Cub Cadets! I have a question. I currently own a 70 Cub Cadet 107 with a IH 42 inch snow blade. I am currently trying to buy a Cub Cadet 129, and I am curious if the sub frame mount would be compatible with the 129. Thanks for your help!
Old 09-05-2025, 11:35 AM
ironman's Avatar
ironman ironman is online now
The short answer is no.
Your 107 is a narrow frame (11"wide) the 129 is a wide frame (13" wide).
Therefore the sub frames where they slip into the quick attach lock have to be the same width.
Your NF sub frame is likely 489618-R1, you would need sub frame 549068-R2.
The blade should fit either frame.
Old 09-05-2025, 11:47 AM
Okay thank you for your feedback! I was guessing that would be the case, thanks!
