Old 01-12-2026, 11:36 PM
champ champ is offline
Default Carburetor Baffle Gasket Purpose?
I have been wondering, what is the purpose of the "baffle gasket" in the carb? What does it do? Carb diagram attached.
Old 01-13-2026, 07:22 AM
ironman's Avatar
ironman ironman is offline
That's a baffling question.
Old 01-13-2026, 08:30 AM
It helps to keep the fuel in the bowl from splashing around excessivly in a rough usage situation, that can cause a rich mixture/flooding.
There is also a very light hair spring in the bottom of some bowls that try to push the float closed in a rough terrain enviroment, but it is a light enough spring that the weight of the float can still drop to allow fuel past the needle valve.
To sum it up, its a means of keeping fuel at the proper level in the float bowl.
Old 01-13-2026, 03:46 PM
Grandpa53 Grandpa53 is offline
The BAFFLE gasket keeps fuel from sloshing into the atmospheric vent.
