Old 01-30-2011, 06:41 PM
CCdude's Avatar
CCdude CCdude is offline
If you are able, try a condenser from a known running tractor. These engines will start and idle with no condenser but fall on their face when you try to give them any throttle.
Old 01-30-2011, 08:05 PM
cubcadet109 cubcadet109 is offline
I checked the choke yesterday, nothing. If i just unhooked the condensor, would it have the same effect as if it were bad?
Old 01-30-2011, 08:22 PM
Check your coil...
It may be bad.
I had the same problem on a few cubs.
Somewhere there is a post about checking one,Most of the times the ones I replaced had the bottoms pushed out...
Up to 534 and counting...
Old 01-30-2011, 10:25 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
I had the same thing happen a wile back on my 782. I tried all the tricks,playing with carb. points etc. It would idle,but back fire and run really bad if I tried to open er up. Some one told me to try a different condenser,so I pulled one off of one of my other cubs. Started it up with a different condenser ran great. Ordered new one haven't had a prob since.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 01-31-2011, 06:13 PM
ok guys thanks for all the help. it turned out to be the coil. usually when my coils go bad it cuts out when its hot, but this did it right away so i wasnt leaning towards that. thanks again for all the help, it runs perfect now just in time because were supposed to get 0-18 inches of snow 25-40 mile an hour winds. no school for me hopefully
Old 01-31-2011, 06:18 PM
rmunro's Avatar
rmunro rmunro is offline
Glad you have it working. Now to get mine in shape!!
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 01-31-2011, 08:01 PM
Just checking.was the coil pushed out at the bottom?
Old 01-31-2011, 08:38 PM
yes it was
Old 01-31-2011, 08:47 PM
APPALACHIAN EDGE's Avatar
APPALACHIAN EDGE APPALACHIAN EDGE is offline
MY 0.2 cents! Might wanna go ahead & switch condensor out to as lil as they cost ! Ive found most of the time they like to hang on & put you through the mill ! They usualy dont go bad all at once ! if you have been jump starting it, Alot of times thatl burn your coil up & it will get hot & push bottom out 99% of the time, but not always! you can run it without condensor but itl eat ur points up in no time ! TIP: Always buy condensors in pairs !
I won't be wronged, I won't be insulted & I won't be made a fool of !
I don't do these things to others & I require the same from them !!
