Old 02-09-2011, 03:11 AM
andre#4 andre#4 is offline
Default Best repower option for tired 73
I was thinking of using the motor from a 147 in my 73. Will this work? (i believe 147 is narrow frame, but some people told me it will not work.)
If it won't work, why not?
Also, are there any better ideas for a gasoline engine with more power?
I don't have the replacement motor yet. So, awaiting advice.
Thank you
I love my 73 and want to use it again. I'd rather repower with more power than fix the old motor with bad carb and bad rod knock.
Old 02-09-2011, 06:51 AM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default 73
I just got a 73 with a rebuilt motor, its a good runner. Lets see some pics of yours !! I believe the biggest motor without modification to the frame you can put in there is a K301 12hp motor. I am sure someone with more knowledge will chime in !!!
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 02-09-2011, 07:56 AM
You will have to do some modification to the frame to get the 14HP to fit.
The 147 frame has modification from the factory for the bigger flyweel to fit.
Old 02-09-2011, 08:03 AM
ljones's Avatar
ljones ljones is offline
Other than expanding the frame around the flywheel it is bolt and go.
Old 02-09-2011, 08:50 AM
Thank you
Do not use the motor from your 147! You will have to cut your frame to get the 14hp to fit into the frame. If your going to repower it locate a better replacement engine.
Old 02-09-2011, 10:02 AM
mc25a mc25a is offline
I've wondered if one of these Lomardini (Kohler) diesels could be made to work.
http://www.surpluscenter.com/item.as...atname=engines
The one listed above is at a good price but may have some issues like no charging capability.
Old 02-09-2011, 04:44 PM
With wanting to use the correct paint and tires on this tractor you will be wasting your money if you put a different engine in it. I would get a Kohler manual, pull apart the existing and rebuild it. The 73's were a pretty low production machine.
Old 02-09-2011, 05:04 PM
Merk Merk is offline
I agree with Oak. The 73 is a low production model. Do yourself a favor and keep a piece of history original.
The Lomardini has a taper crankshaft on it. Odds are you are going to have to modify the frame to make that thing work.
Old 02-09-2011, 05:47 PM
I gotta agree with the other guys, your 73 is more collectable left as a 73. Anyone can chop up a Cub and poke a big motor in it, not near as many of us have a nice 73 though.
Probably should restore your 147 too, not very many of them left around either...
Old 02-09-2011, 06:46 PM
Jay's 73 looks awesome! Have you checked out his thread yet?
http://www.onlycubcadets.net/forum/s...ead.php?t=8610
