Old 07-14-2009, 08:51 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
Default Smokey the 782
Last year, my 782 started to smoke a little at start up. This year, she smokes a lot at startup, and at slow down after mowing. The smoke clears after a little bit. Fuel consumption is normal.
There is oil in my air cleaner housing. I already changed the crankcase vent and the tube is not clogged either. I had one of the heads off earlier this year, and the cylinder looked good. Could I have bad valves?
Anyone have this happen before? How much longer will the engine live? I hope the move to flat ground from the slight hillside I live on now will help prolong the life of the engine. I think it is a Series II, but the air cleaner housing just says Kohler, 17HP. I'm running SAE30 oil.
Thanks!
Old 07-14-2009, 09:59 PM
murphycc
Guest
Posts: n/a
valve guides and rings.
Scott
Old 07-14-2009, 10:05 PM
IAfarmer's Avatar
Valve guides need to be pressed in, don't they? I may be motor hunting soon.
Old 07-16-2009, 02:18 AM
aagitch's Avatar
aagitch aagitch is offline
I'm not saying yours isn't, but most Series II engines will say "Kohler 17 Series II" on the air cleaner. One way to tell is look at your spec number on the ID tag. If it's not a series II, I wouldn't mess with doing any overhauling to a Series I.
