Old 04-27-2011, 12:39 AM
Originally Posted by Mountain Heritage View Post
You can search from your profile if your looking for "any" of your postings or threads "started" by you. I might take a little bit, but it will find it. Much easier for the threads "started" by you. Just throwing out
Originally Posted by william1041200 View Post
I think thats how I found my thread before, when I subscribed to it. Thanks for making me .02c richer Mike!
I do it the same way Mike suggested.
Old 04-27-2011, 01:44 AM
cub149's Avatar
cub149 cub149 is offline
If you install google tool bar, it has a search box with a pull down menu and you can select "search this site" and it does a great job on any site you are looking at. I use it all the time, hardly ever use any sites search options.
Just an option you may want to try
Chip T.
Drexel NC
Old 04-27-2011, 08:29 AM
TEET's Avatar
TEET TEET is offline
I agree with Chip, thats probably the best way to search a forum like this. I think this is actually a software thing, and its not necessarily a problem, or non existent on many forums. The problem is the number of letters or numbers being searched, I've found that typically 4 to 5 letter words or number sequences are the minimum on most forums, and numbers are particularly hard for some reason. As an example If I go to any one of my gun forums and type in .308 I get the same answer on all of them...no results, but if I type in Ruger, or Winchester...whammo...tons of results. Make sense...I'm no expert, but I think its just the way the software is designed
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 04-27-2011, 08:36 AM
I think this is correct.
I use Google for searches every day in my business. Google is good at providing 50,000 hits in .3 seconds.....BUT....I have to wade through tons of useless information until I can find what I really want. They throw too wide of a net.
Old 04-27-2011, 08:22 PM
william1041200's Avatar
Im glad we all learned something new about the software. It has to be written to work, and it only works as it was programmed. I feel I have said that before. LOL I had no gripe about it, just added to the post, as I could not get it to work for me.
Old 04-27-2011, 08:25 PM
UPDATE...
The "minimum" character length for this software is "4". This means, you have to have a minimum of 4 characters for a valid search to begin. Anything less will produce a "no match" pop up.
Old 04-27-2011, 08:32 PM
UPDATE #2
I tried "Cub 104" and came up with nothing. Both Cub and 104 were less than 4 characters.
I tried "Cub Cadet 104" and came up with tons of hits.
At least one word in the box, has to be 4 or more characters to have a successful search.
Old 04-27-2011, 09:22 PM
Iluvtruks0's Avatar
UPDATE #2
That should be a sticky! I too have had this problem. Thanks for clarifying.
David in NC
Old 04-27-2011, 11:34 PM
I agree. should be sticky!
