Old 06-03-2011, 05:35 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default a little insight, if you please.....
if off color talk offends you then hit the back button!!!! LOL seriously, i have just recently acquired a 1982 allis chalmers 716. it has a broken rod and also it has the balance gears. my question/comment/what have ya! if a motor came with the BG's do you HAVE to put them back in? i mean, they were designed to have them YET only one of the kohler motors i have has them (69 14hp economy). i realize that it reduces the vibration, but i'm not going to cut grass with it, just use it as a bigger tractor. i really don't won't them in there because on more than one occasion, i have heard of them letting go and doing ALOT of damage. everyone please give me thoughts and opinions. thanks, jeff i will post pics later
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 06-03-2011, 05:58 PM
TEET's Avatar
TEET TEET is offline
Their designed intent was to reduce vibrations on Kohler singles, but the extent of vibration dampening goes almost unnoticed...at least to me, and I've run and heavily used tractor with, and without them. I usually remove them when I rebuild a block only because they have been known to grenade and destroy other internal engine components.
So my vote is.... if your in there, take them out... if you dont have any in there now, leave it that way
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 06-03-2011, 07:19 PM
I thought I was going to lock this thread when I first started reading it. If the BG's are in there get them out of there! Nothing good will come out of leaving them in there!
Old 06-03-2011, 07:31 PM
jeffscub's Avatar
sorry, i have a way with words sometimes.
Jeff
Old 06-03-2011, 10:16 PM
william1041200's Avatar
I have a way with words myself! I agree with the rest, leave the balance gears on the bench! They were a horrible engineering idea.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 06-03-2011, 10:49 PM
jmroy's Avatar
jmroy jmroy is offline
I just got to that point in disassembly with one of my engines that has them. Is there any way to/should i remove the shafts they're mounted in? It looks like I can drive or press them out but that would leave two holes in the block?
Web Developer - Need a website? Contact me.
Old 06-03-2011, 10:55 PM
The shafts will be fine. If I am not mistaken, they are machined in the block, no way to remove them.
Old 06-05-2011, 12:11 AM
jeffscub's Avatar
here is a picture. jeff
Jeff
Old 06-05-2011, 10:19 PM
Nice AC, Jeff!
Old 06-06-2011, 05:48 PM
Shaner Shaner is offline
you can never go wrong with an Allis Chalmers or Simplicity! great machines. almost like them more then cubs
