Old 08-12-2011, 04:11 PM
PurplDodge's Avatar
PurplDodge PurplDodge is offline
You must not have had a Kohler Command...they don't have these oil leakage issues.
I have had a Kohler Command. It sucked fuel like nothing else, overheated, and had little power....But they do sound cool, like a Harley Davidson.
1992 Cub Cadet 1440 1,400 hours, 44'' Deck, 42'' IH Dozer Blade, Light Bar, All Trail tires,
16 year old Cub Cadet owner!
Old 08-20-2011, 02:39 PM
superG superG is offline
Default More smoke!!! Now with pictures!
OK --- I replaced the oil filler cap. I replaced the gasket around the dipstick. Both of these were cracked. I did my best to clean up the oily mess. Today I had to mow again, and at first there was just a little bit of smoke. I figured this was old spill that was just burning off. It stopped after a bit, but then towards the end of the mow, it started smoking again
As you'll note, the front of the tractor is now an oily mess. So is the entire engine compartment. I parked it in the garage over a piece of cardboard and there is dripping everywhere.
Here are some pictures:
Old 08-20-2011, 03:40 PM
Crank seal???
Old 08-20-2011, 03:51 PM
Crank seal???
My wifes uncle had the same problem on his 1862 crank seal.
Old 08-22-2011, 07:47 AM
Thanks for the help on the Dx. I'm not sure my skills are up to trying to replace a crank seal. There is a local CC shop that has pick-up service and I'll be giving them a call this morning.
Old 08-22-2011, 02:49 PM
Let us know how things turn out please..
Old 08-22-2011, 04:32 PM
Ditto!
Old 08-22-2011, 06:23 PM
Vince_o Vince_o is offline
Yep crank seal. I did one of them at the mower shop for a guy. Piece of cake, you all know how fat I am, and how I like cake. The hardest part is all the sheet metal screws in a dang vanguard! Youll get a coffee can full of them!
Old 08-23-2011, 06:43 AM
PurplDodge's Avatar
If you can change the dipstick seal, you can change the crank seal. Piece of cake. Just make sure to put some anti seize on the crankshaft so if you have to ever take off the PTO clutch, it slides right off.
Old 08-23-2011, 09:59 PM
PD
I use it on all my pto and on the manual pto, basket, and berring, good advise.
