Old 08-25-2011, 01:30 AM
hydrocub hydrocub is offline
As Matt said , the right side is accesible . To do the left side involves
a tear down . Only then do you need to ( or should ) replace all seals .
Old 08-25-2011, 06:23 AM
Vince_o Vince_o is offline
If I could replace the seal with out taking the hydro apart I would. Like somone said its no a smal job. You dont want any dirt to get in there. So just pulling the one side would be easier and less risk of dirt.
Also you can replace the seal between the rear and the pump with out splitting the tractor on the wide and split frame tractors.
Old 08-28-2011, 11:39 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Got the seal ordered, hope to fix it in a week or two, thanks gain on the infro
Donny
