Old 11-13-2011, 09:35 PM
emptypockets95's Avatar
emptypockets95 emptypockets95 is offline
i run a 450 deka....havent had any problems with it in my 1572! I had a magnum form IH and it didnt do a very good job
Justin
Old 11-13-2011, 10:04 PM
Iluvtruks0's Avatar
Make sure to use post covers to protect the hood.
DITTO!!!
David in NC
Old 11-14-2011, 06:36 PM
TheSaturnV's Avatar
Doing the starter conversion for diesels will also help out with the battery issues.
Old 11-15-2011, 06:50 PM
125 cubowner's Avatar
125 cubowner 125 cubowner is offline
Just thought I woudl drop in and say awesome about buying Deka Made in USA and also that Briggs battery is also a Deka
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 11-15-2011, 07:57 PM
CC1650Dave's Avatar
Originally Posted by LiamD View Post
Thanks DWayne,
I found a brochure with the factory folder formmy 1872, and it has all the battery sizes and measurements far all cub tractors.
I'd like to see that document, do you have it in electronic form? I need to figure out what's the biggest battery with the most amps I can put in the 1450 and 1650.
Old 11-16-2011, 02:04 PM
LiamD's Avatar
LiamD LiamD is offline
Default 1572 Battery
Hi All,
I went with the Deka battery. Installed last night, the tractor has the gear reduction starter on it and it starts with no problem. I did put the rubber terminal covers on it though as they did seam pretty close to the hood. The battery chart does not cover the older models, on from the 80's era.
Thanks again,
Mike
