I'm new to this, so please forgive me for asking what may seem to be a dumb question.
On my Cub Cadet model 125, I am looking at the breather cap for the Danco RD2000 bucket loaders hydraulic fluid, which is located on top of the right side vertical frame...near the control levers.....and I cannot figure out how to remove the cap to check the fluid level and fill as may be needed. I have turned the cap round and round, this way and the other way, but it does not come off. I am reluctant to get forceful with it or attempt to pry it off until I understand better how it should come off. Under the cap there are large diameter but very thin nuts...access for a wrench may be a bit tight. I sure appreciate some good direction on this before I go and break something unnecessarily. Thanks very much. Jim |
This may help...... click on... Manual
Thanks for the manual...that is very good information to have on hand...however, it does not mention anything about the access to the hydraulic fluid reservoir...other than to remove the cap and check the fluid level.
Here is a photo of the cap...and I have tried pulling up...pushing down...rotating it each way...many turns...all to no avail. Do you think I should get at those nuts just under the cap and give that a try? Is the fluid under pressure at this point? And...many thanks to you for your postings on the starter/generator system. With your guidance I was able to correct some incorrect wiring and see the generator actually charging! How wonderful it is to achieve a bit of success. You are to be congratulated for you efforts on our behalf. Jim ![]() |
Jim that looks like a breather cap on top. The system is not under pressure. I would do what you suggested and thats put a wrench on that nut under it.
We need more pics of your loader! ![]() |
Forgive the appearance...I am doing some work on the machine...so the hood and grill have been removed.
Note: After removing the hydraulic filler cap...which turned out to be a made up thing of several brass pipe reducers, and filling the loaders hydraulic fluid reservoir to the specified level....4 inches below the plug....I operated the loader to get the fluid in and air out.....but when the bucket was returned to ground, I noticed some fluid being forced out of the plug breather cap. I am thinking of scrapping that home made breather cap and installing a simple brass pipe plug and stop the messy goo from ooosing out and flowing down the reservoir frame. I think the manual mentions a plug...but not a breather? I guess it can't hurt anything,eh? Enjoy the photos. Jim |
you cant just put a plug in it..... it must be able to breath, as the cylinders push out, fluid goes into them and therefore out of the reservior. at that time the reservior will go into a vacuum. when you put the cylinders back to close, the reservior will go under pressure..... thats not good.......
I guess I have a lot to learn about hydraulics. But what can I do about the breather spewing fluid out when the bucket is retracted?...maybe just let it reach equilibrium, and stop spilling fluid on its own?
jim |
Jim was the loader running when you lowered the bucket when it forced air out of the breather? My Kwik-Way will force oil out of the breather if I lower the bucket with the tractor off.
Awesome set up! Is that a IH weight box? Looks homemade from the side but still looks great! How much weight do you have in the weight box? Thanks for the pics! |
Nothren tool sells breathers or any place that makes hoses should have them.
I bought the machine as you see it, with no prior knowledge about Cubs...or tractors for that matter....but I am learning....Oh boy, am I learning!!!
The weight box may be home made, but they did a fine job of it. The weights are simply concrete .....probably poured into a temporary wooden form properly sized to fit a pair of them into the weight box, with a "U" shaped piece of re-bar imbedded in each of them to serve as a convenient handle. I would guess them to be about 50 pounds each. I was under the impression that the hydraulic system would be a closed loop that would bleed fluid back and forth internally on opposite sides of the piston so as not to need a breather in the loop. I guess I'll just have to find a breather that doesn't allow fluid to flow back out. I have a Northern Tool store not too far from me...thanks for the tip. jim |
Thread Tools | |
Display Modes | |
