Old 12-20-2011, 06:00 PM
lilkrou lilkrou is offline
Default Original spring trip plow and snow thrower
Can anyone tell me if the lifting rod from a BB36 snow thrower will be the same for a spring trip snow plow.
Also, was the spring trip snow plow (or blade, correct me if I am wrong with the terminology!) a CC product or Brinley or someone else? Model number would be cool to know as well so that it may make it easier to find parts, etc.
Thanks for the help, I am learning alot on this forum, but still have a lo-o-ong way to go!
Tony
Old 12-20-2011, 06:26 PM
mmzullo mmzullo is offline
There are 2 different lift rod lengths. I'm not sure which is for which.
Old 12-20-2011, 09:03 PM
Thank you for the info.
Old 12-20-2011, 09:27 PM
You can use the guide to make your own or look for a stock replacement.
http://www.onlycubcadets.net/forum/s...ead.php?t=4616
Old 12-20-2011, 10:02 PM
That is awesome! Thank you for the information!
Old 12-21-2011, 09:16 AM
A lift rod for an original has a couple curves in it. I'll see if I can find a picture. It actually goes in the center of the frame and you cant see it except for the tip of it. Look here the part # is here also. http://www.cubcadetcollectors.com/fo...tail&df_id=138
