Old 12-21-2011, 12:58 PM
72-149's Avatar
72-149 72-149 is offline
Originally Posted by drysumpjet View Post
Another post somewhere showed a block crack around the exhaust port area, which may have been caused from a stack installation that was poorly supported.
I'm not sure if my support is a "cure" for stacks, but it should help with block cracking concerns. The plate is 1/4" aluminum, note it's supported underneath by flatstock to where the Quietline lower muffler shield is attached to the block. (The block is from a 1650)
The stack pipe is made of scrap stainless steel swimming pool ladder pipe I polished. Too bad the engine ran "lean" and "blued" the pipe before I had a chance to drill out the main jet in the card to richen it up a bit.
It's also got the insert muffler inside the pipe as I mentioned on the old forum.
just a qes. how come both your tractors have the frontires back wards ?
Old 12-21-2011, 02:01 PM
Those are not backwards, those are on the correct way.
Think about it!!
Old 12-21-2011, 04:35 PM
Non-powered lug tires are supposed to be installed that way.
Old 12-21-2011, 06:45 PM
Donovan M.'s Avatar
why are they supposed to be that way.
Donovan:
62' Original-fenders
Old 12-21-2011, 11:37 PM
alsparl alsparl is offline
Donovan, I will try to use my knowledge from working with our auger cart on the farm. If the front wheels on his tractor were "driven," like a front wheel assist tractor, the tread would be facing forward (to "dig in"). You see this on any front wheel drive/assist machine.
Our auger cart has the tread facing backwards, resembling what is on the front of his lawn tractor. The reason is because the auger cart wheels are being "pulled." With the tread facing that way, instead of "diggin in," they will "ride on top/rize to the top" of the ground. In the relm of the lawn tractor, the front wheels are being "pushed" and don't need to "dig in." Facing them in that direction will keep them on top of the ground, which will allow them to operate properly as steerable wheels.
I hope this helps as its the only way I can describe it.
Old 12-22-2011, 12:17 PM
drysumpjet's Avatar
drysumpjet drysumpjet is offline
Default Front Lug Tires Lug Direction
To add what others said... When cornering, the outside edge of the outside front tire is what's doing most of the work in making the tractor turn. It's best if the outside edge of the outside tire lug placement is 90 degrees from the natural force that is trying to make the tractor go straight. Really makes a difference turning on poor terrain.
Old 12-22-2011, 02:43 PM
Donovan M.'s Avatar
oh i didnt know that
Donovan:
Old 12-24-2011, 05:15 PM
oldsasquatch's Avatar
oldsasquatch oldsasquatch is offline
Thumbs up
Nice workhorse you got there!!
Looks like you treat her well!..... I'm drooling!
oldsasquatch
1994 1440 Cub Cadet
14hp Vanguard Briggs & Stratton
42in. mower deck
42in. blade
200lb wheel wts.
rear Ag tires & chains
2" reese hitch sleeve
Old 12-29-2011, 08:25 PM
Fozzy's Avatar
Fozzy Fozzy is offline
Default Stacks
Tractors have to have a stack or two. It is just makes them cooler.
Old 02-23-2012, 09:40 PM
ihnick's Avatar
ihnick ihnick is offline
Here's my stack. I just did it half a$$ed and cut angles with a chop saw and welded together instead of trying to bend it. I left the factory manifold pipe on the block too. It looks and sounds cool
Nick.
