Old 01-17-2012, 03:53 PM
FarmFresh's Avatar
Default 1810 Diesel Project
I have had a bunch of problems with blowing up kohler twins so I decided to start my diesel cub project. I acquired a kubota d905 and I am installing it in my 1810 parts tractor. The engine is in and barely fits, the throttle linkage is done, the driveshaft is hooked up, and the radiator is mounted. I also decided to install a hand pump air ride seat on it. Now for the hard and expensive part of finding hooking up power steering, and fitting a fuel tank. After I get it running and driving I am going to install a front end loader on it that I bought for another cub. Hopefully I will be able to piece together a cat0 3-point before plowing season. Here are a few pics, sorry for the crappy cellphone quality.
If anyone has power steering parts forsale please e-mail or PM me.
djweeks@mchsi.com
149 Raised Bed Tractor
1512 Being restored
1450 Missing its heart
Original 1961 Red No options
782D Missing Engine
Old 01-17-2012, 05:00 PM
Very nice! Thanks for the pics.
Please place a wanted ad, in the Wanted Items section of the site. This isn't the place to place an ad. Thanks!
Old 01-17-2012, 06:52 PM
Looks like you are having some fun.. Can't wait to see it completed.
Old 01-17-2012, 07:45 PM
Looks good. What type of radiator are you going to use and do you have any close ups of the enginge cradle and drive shaft flange?
Old 01-17-2012, 09:23 PM
FarmFresh's Avatar
The radiator is out of a honda civic, I just fabricated the mounts and rubber isolators, and the drive flange is a modified piece of a kohler that just needed a little adjusting on the lathe.
I will be taking some more pics in the next few days.
1512 Being restored
782D Missing Engine
Old 01-17-2012, 09:38 PM
It is a diesel, its going to need a bigger muffler!!
Great looking conversion. Couldn't resist commenting on the muffler. Will the manifold hold that muffler up??
Old 01-17-2012, 10:00 PM
I'm wondering the same thing. I have heard of cracked exhaust manifolds on the Kubota engines.
Old 01-17-2012, 11:37 PM
FarmFresh's Avatar
That is not the exhaust that I am going to run. It was on the engine when I had it on the running stand. It was thrown together so I could run the engine in the shop and not go deaf. It will have a much nicer looking exhaust when it is done. Thanks for the replys and the comments.
1512 Being restored
782D Missing Engine
Old 11-03-2013, 12:46 AM
FarmFresh's Avatar
Default Finally an update and steering!!
I spent today adding power steering to my 1810 Diesel project. I used power steering parts from a JD318 and modified them to fit the cub. Space is very limited with the large Kubota engine so it took a ton of cutting and welding to make it all fit. I had to remove 3 inches out of the steering column and that was a fun task. Then it took a while to get the spindle and cylinder geometry figured out and to get the spindle reinforced, but now just a few lines and it will be moving and steering. I did not take any pics during but here is a few when it was done. I raised the column a bit over stock, but with the air ride seat it is super comfortable (especially since i'm 6'4" tall). Hopefully I can get the hydraulic lines and the foot hydro controls built this week.
1512 Being restored
782D Missing Engine
Old 11-03-2013, 07:26 AM
Thanks for the update! Looking good!
