#21
Clay |
#22
I suppose you could add a rust preventive to the anti freeze before putting it in. I've seen it at auto parts stores.
#23
Yes the used antifreeze can carry heavy metals but sitting in a 55 gallon drum and just take it off the top should be ok. There is rust inhibitors in antifreeze already. With used stuff I'm not sure.
#24
I hope I never have to say that word. It is illegal to make shine, that's why they make fuel instead. ![]()
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
#25
It seems that some of you have gone to a lot of trouble to fill your tires. There is a little device that fits inside of the valve stem that allows you to fill the tire very quickly. It is not very expensive and can be reused many times. I got one at a tire store that sold a lot of tractor tires. It works with a garden hose of any type of pressurized sprayer. I used antifreeze and water at 50/50.
1811 Hydro "Failing to prepare is preparing to fail".
#26
I've used that valve contraption from Slime.
#27
Like Methos said use Rim Guard. Thats what i used and i got 80 lbs per tire for weight at about 30 bucks. It also helps the farmers!!! Its 100% bio degradable and made from sugar beets! (keep me working). It does not rot rims either.
Justin
#28
What does it offer for freeze protection? I have not found a Rim Guard dealer in the NY capitol district.
Clay |
#29
. Rim Guard™ is nearly 30% heavier than water. . Rim Guard™ is non-corrosive. . Rim Guard™ is non-toxic and biodegradable. . Rim Guard™ is freeze-resistant down to -35°F. . Rim Guard™ is cost effective because inner tubes are not needed and tires are easier to repair. I've been using this in my farm tractors for about 8 years now, it is FANTASTIC. You want to see BIG $$ try replacing a 40" rim on an 11,000 lb tractor because of calcium chloride damage. Almost rolled that tractor on a hillside, the downside rim just collapsed, the rims looked fine on the outside...very scary. Don't know current pricing but worth looking into for my GT's when the time comes. |
#30
Holy crap! Started a good thread! LOL Ya they are all good points I would be interested in the "Rim Guard" if the price was resonable? I didn't think the WWF would be as corrosive as the calcium ? Anyone have a link, my tires are new no problems leaking might have to drain one down in spring and see what it looks like in there? Ya a lot of stuff is bad for the environment and I think long as its used and not abused will work. I use the end of an old 12v tire compressor with the valve stem clamp, then hose clamped it to the G sprayer. That garden hose setup sounds really good tho!
Sam My Cubs 108 & 1250 & 104 Tiller, snow thrower, Plow
| Thread Tools | |
| Display Modes | |
