Old 01-29-2012, 02:53 PM
Foolster Foolster is offline
Default Lug bolts with larger diameter heads
I recently picked up a set of 26 x 12 x 12 ag tires mounted on rims. However the rim holes are too large for the lug bolts on my cub cadet 582. Does someone make the 7/16 fine thread bolts with larger heads?
One alternative I thought of was to buy washers and weld washers into the rims to make the mounting hole smaller.
I have noticed on the web several places where car rims could be used on cub cadets. Don't car rims use a larger hole size for the lug bolt? What lug bolt would you use to mount a car rim to a cub cadet? Or do you switch to studs and lug nuts?
Old 01-29-2012, 03:02 PM
The 26 x 12 x 12 tires were designed for Cub SUPER garden tractors. The 582 is a regular garden tractor and the appropriate tire size for it would be the 23 x 10.50 x 12.
If you are going for "the look", then adaptation would be expected.
Old 01-29-2012, 04:08 PM
jbollis's Avatar
jbollis jbollis is offline
go to your local bolt store and get some longer bolts with regular heads on them. Then you can thread them in from the back (inerside) of the axle flange. Use lock tight on them and get them good and tight. Then you will essentially have lugs (studs) on the outer side. Then you can use regular lug nuts.
Sold everything but one.
Old 01-29-2012, 04:21 PM
Or just simply get the correct wheels for a CC for that size tire.
Old 01-29-2012, 08:37 PM
I like jbollis's idea. Just get some studs and mount them up
Stock can only be so fun.
Tags
large head lug bolts
