#71
Dave
The plastic is almost perfect. I had a 1641 with busted pins that I fixed by using some 3M structural adhesive to glue some studs in the hole in the center of the broken off pins then I just put nuts and washers on. Lower one is a bit of a PITA because you have to pull the grill off to get at it but it was the only way I could come up with to save the panel. Worked good. I'm thinking about making a mold and building a dash pod to house the gages rather than cutting up the dash. If I do that I may make a few of them for sale. May get stupid and see if I can get one of old racer buds to do them out of carbon fiber. ![]() |
#72
Looking good Sam!
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
#73
![]() Quote:
#74
Too bad it's 660 miles from me, but I have an 1862 dash that had a couple of PO mods done to it that would be perfect for your modifications.
#75
Them be some mighty fine looking supers kinda like super supers. One reason there are not so many cub fanatics in VA you two have all the good ones. lol
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
#76
Paul
I hauled these two home from St. Louis, not exactly just around the corner. Matt If you have a pic of the dash mod I'd love to see it. Going with SW gages I got from Summit racing, mech oil press, elec water temp only because the sender in the Bota is only 1/8" npt, a volt meter and hour meter. I'll probably stick with the gas low leval light. |
#77
I don't have a picture of it...only thing that got done with it was the addition of a few small holes by the PO for switches and stuff, so consequently it is more or less worthless to most people.
#78
Matt
I was just going to take a hole saw to the dash but the tower has a rib exactly where the gages need to go and I'm concerned it would weaken it so I'm going to make something up that will space the gages away from the dash and run the wiring through the holes that the bulbs were in. Plus it has to have the cool factor going on and just because I have to be different LOL ![]() |
#79
#80
Originally Posted by Dave01
Sam, that looks like it's new on the showroom floor! It sure does!
Thread Tools | |
Display Modes | |
