#21
Very very nice work. I would like to do the same thing on my 149, only a dual brake. You have given me a nice guide to start with.
Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
#22
Well, I got it back together and running yesterday. The new brake pedal works great. I still need to figure out a parking brake for it. While I had it apart I spray bombed a few things like the wheels and the grill mesh since they were covered in surface rust. I also painted the gas tank and made a new set of stainless straps. The old straps are too long since the tank on it is obviously for a 70 and the straps were for the bigger 100 tank. I'm now working on making a mounted salt spreader out of a tow behind broadcast fertilizer spreader.
#23
IHinIN,
Your 100 looks great! I really like your brake pedal. I've really enjoyed your pics of progress!
#24
Thanks ACecil.
#25
Well, it only took me 4 years to get this project done. Today, I finally made a parking brake latch. I built it similar to the old Farmall setup with a ratchet plate and a catch on the pedal. The Farmalls had the notches on the pedal and a spring loaded catch hooked to a handle to set the brake. Stomp on the pedal and the catch releases. Now I no longer have to shut off the tractor in gear to keep it from rolling downhill.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
#26
Great job Adam.
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
#27
Nice job Adam!
#28
Top notch job, Adam!
#29
Very Nice!
#30
Where did the offset pedal go. I don't see the lift handle ether.
I do see that you have a different lifting attachment. So does the lift rod for the front attachments run on the outside of the brake pedal now?
Doug 126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights 129 Deck, Blade, Weights 1200 Creeper Deck: 1250 B Tiller odd deck 782R with power steering ![]() ![]() ![]() ![]() ![]() JD 110H:JD 112H |
| Thread Tools | |
| Display Modes | |
