Well...I have been looking for a week so I finally bought my first one...what do you think?
I paid $1400. The good: No rust Runs strong Drive shaft replaced last fall The bad: PTO switch must be held up for mower deck to work Headlight switch broken Mower deck pretty well worn Went to start it up to back off the trailer and the starter won't engage! No clicking or anything! Fuel pump runs...ideas? ![]() ![]() |
Uh , WOOOOOOW !!!!
The starter and PTO switch are available from one our sponsors. Your starter not engaging may also be the ignition switch , so you might do some testing.
The deck looks good in your pics ???? |
Horrid, I will gladly give you, your money back to try again. LOL Just picking great find some people have all the luck geez
I really do like it. congrats
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
You did very well!
You did great on that one! Super sweet score.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]() ![]() |
![]() Quote:
Starter worked fine a couple of hours ago. PO disabled the safety interlock on the brake... But I pushed it in anyway. Glow plugs work, fuel pump runs, but no starter noises. Ammeter does register heavy discharge though when I turn the key. |
Bill, you did well. The PTO switch has a contact that is closed when it is in the off position. The tractor will not start unless the switch is "off". Wigle the switch with the key in the start position to see if that helps. There is also a brake switch that must be closed for the tractor to start. Your starter could also be going bad as well. I would check the switches first. There is a starter upgrade post on here somewhere that explains how to replace the starter. Also check all your ground wires. I think there should be 2 heavy ground wires, one on the frame and one to the engine cradle or block. Good luck!
With a simple jumper cable from the battery to the starter (Positive) and the other to ground on the frame will tell you right now if it is the starter. I would do that first to save all of the safety switch detective work. Everyone is right here but if you want to know up front whether the starter is bad jump it. Otherwise you got a great deal in my opinion. I prefer yellow and white but red will do in a pinch!
1811 Hydro "Failing to prepare is preparing to fail". ![]() |
Thread Tools | |
Display Modes | |
