Old 04-01-2012, 09:17 PM
bmbigdaddy bmbigdaddy is offline
Default 1210 Hydro help!
Hope this post is at the right place, I installed a M-12 off of a 1204 on my 1210. The M-12 has electronic ignition, can someone tell me where to hook the white coil wire on the switch?
Thanks for the help.
1872,1210
Old 04-01-2012, 09:32 PM
Kris Brown's Avatar
Kris Brown Kris Brown is offline
Go to the Technical Library for tractors, it's on the main page under the Resources section. Go to page four towards the bottom and click on wiring diagram-82 series. Scroll down to the second diagram, which is for a 1282, 680, and 1210. But if you can describe in better detail what it is you need, I can look at my 680. Hope this helps.
Kris
63 CC Original w/ 38” deck and front plow
72 129 50” deck, 42” blade
73 86 42” deck, 42” blade
84 CC 680 w/50” deck and 42" plow
89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2
1982 Gilson Lawn Tractor with 38" deck
Old 04-01-2012, 10:11 PM
thanks my 1210 is like that but the 12mag i put on has one wire from the internal coil that grounds out to stop the engine (i think) and it needs to go to the switch but it also needs to get no power to it ,or thats what i was told and thanks for the diagram info !
Old 04-01-2012, 10:21 PM
Some guys here have done a swap like that and can help out with the wiring. Give them some time to see this post and reply.
Old 04-02-2012, 08:33 AM
juniors1282's Avatar
I put a M12 from a 1204 in Hunter's 1210 and dont remember having any extra wires anywhere. It dropped right in, I hooked everything up and she fired right up. I'll look at it today sometime and see what it looks like for ya.
1966 IH cub cadet 102x2
Old 04-02-2012, 08:38 AM
There are two different wiring diagrams for the 1210. What is your chassis Serial Number??
Old 04-02-2012, 07:55 PM
serial no. 2050603u744956 model no. 145680100 thanks for your help!
Old 04-03-2012, 07:01 AM
It appears the 1210 came with two different motors, depending on age. Early models (like yours) had a K-301, and later models had a M-12.
In order to modify a M-12 going into your chassis, you will have to choose, making a decision on: (a) adding a relay, or (b) replacing the Key Ignition Switch.
Please advise and I'll draw you up a diagram.
Old 04-03-2012, 07:22 AM
thanks alot !! i can do eather one u think is best but im not that hot at the wireing thing
Old 04-03-2012, 07:59 AM
Here ya go......
If you want or need a higher resolution diagram, I can send it to you.
