Old 04-04-2012, 10:30 PM
Cub 128 Cub 128 is offline
Default Narrow frame transaxle in a Wide frame?
Can I put a narrow frame 3 speed transaxle into a wide frame?
Will the clutch setup and drive shaft work as well?
What modifications are required for this to work?
Old 04-05-2012, 12:33 AM
It will bolt up no problem but you'll have to custom make a drive shaft. You could pull your axle tubes off your WF rear end and put those on the NF rear end.
Old 04-05-2012, 02:07 AM
red56turbo's Avatar
If you're talking about the whole rearend, they are a bolt in swap out. The original drive shaft and coupler that pins onto the rearend can also be used. One big difference may be internal versus external brakes.
I just swapped a narrow frame rearend into my 800. The 800's original driveshaft and coupler fit like a glove. They were both internal brakes, so a bolt, fluid change, and go swap.
Josh
Diesel Cub Cadets...........
Old 04-05-2012, 07:08 AM
Ok, thanks for the replies. I don't have the driveshaft for my 128 but I was going to buy a 122 roller that has the drive shaft and transaxle.
So I was just wondering if it'll fit up, also how can I tell if my 128 has internal brakes or external?
Old 04-05-2012, 07:13 AM
maddog784's Avatar
If your 128 has external brakes, you can look on the inside of each wheel and see a disc and caliper set. Internal brakes have linkage that runs to the inside of the transaxle housing.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
dieseldan123's Avatar
If you see external brake calipers then it's a external brake rear. No calipers then it's internal brake.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 04-05-2012, 02:27 PM
It has a swapped hydro in it and I don't know if the frame is setup for internals or externals?
Old 04-05-2012, 02:57 PM
maddog784's Avatar
I don't believe that the frames are different between the two. They both have linkage that connects to the transaxle, but from there it either goes into the transaxle, or splits and goes to each of the external brakes. Parts breakdown would probably paint a good picture of it.
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
