Old 04-08-2012, 05:30 AM
cdlong's Avatar
cdlong cdlong is offline
Default More tiller questions
I have a 1450 w/ 42 & 50" decks, 42" front blade, 40" rear blade, sleeve hitch, and QA36A. Now I'm chompin' @ the bit for a tiller. I've found 2 in my price range. The owners can't tell me if they're #1,1A or #2. How can I tell if these tillers will fit my 1450? I do have pics of them. Also, neither has a mule drive. By looking @ all 3 tiller manuals, it appears the mule for my 42" deck will work. Am I correct? One has the lift pin and the other does not. One has a pulley with a chunk missing, but reading other posts, this may not be a big deal. the one with the pulley missing a chunk doesn't have the cover for the large pulley. Is this a concern? I know not to mess with unguarded belts when they are turning. Something else, I need to replace my seat. I was thinking of a high back seat. Will a high back seat interfer with line of sight on the tiller? Tiller #1 is 38" and tiller #2 is 36".
Thanks
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 04-08-2012, 07:35 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
its on the tag in pic 3 you posted. looks like 1A but the pic is a bit fuzzy
my #1
Doug
Original , 100 , 125 , 582
Old 04-08-2012, 11:44 AM
cdlong's Avatar
Thanks for the info. The 1st 4 pics are, unfortunately for a narrow frame and I have a wide frame. Had a good price too.
Papaw
Old 04-08-2012, 12:03 PM
4SPEED's Avatar
it will fit any IH built cub. NF is just a smaller drive belt. my #1 fits my WF 582 fine.
you just need the correct mule for your NF or WF.
Doug
Old 04-08-2012, 12:23 PM
Just to add if you have a 82 series you might need to swap the lower pulley with a 5/8 pulley for the larger belt.
As which one to buy,
Make sure it turns over freeley and the tines and large pulley both move. Then get the one that has both extentions and gear box!
Old 04-08-2012, 12:31 PM
4SPEED's Avatar
^^ yes I should of added that about the pulley on the drive unit being 1/2 V and the WF is 5/8" on my 582 682
Doug
Old 04-08-2012, 12:48 PM
Doug no worries!
Old 04-08-2012, 02:15 PM
I forgot to add that a high back seat will not be in the way. You'll be looking over the fenders but your back will enjoy the high back rest.
Old 04-09-2012, 03:52 AM
cdlong's Avatar
Thanks guys. Looks like we'll be getting a tiller!
Papaw
