Well, I have started to restore a 1450. This restore was not the original intent of the purchase of this tractor. It was intended to be just an engine donor for my 1200 (I guess it would have been a 1400!)
The engine of the 1450 had a damaged oil pan due to neglect of the ISO mounts. ![]() When I removed the engine, I was intrigued by the frame, it must have been a late model, as the front axle mount had slotted holes rather than round holes. ![]() I had not done a "cradle mod" before, so I figured this would be a good experimental tractor. If I failed, the engine would just go to its original intended tractor. The mod turned out perfect. ![]()
Nice work CADplans
I'm looking forward to this one!
Nice work! Need to do this on my 1450.
1200, 1450, Red 782 |
Thanks for the comments!!
I also turned a couple of "frankenstein bolt eliminators". They were made out of 1.50" bar stock. ![]() I prefer having the hitch lift hanging on a solid 5/8" rod the width of the chassis. |
Looking forward to your progress!
The frame is cleaning up. I used a paint stripping wheel I got at Sears.
![]() ![]() I went back for a second wheel, they do not have them any more and I can't find them on the internet!! ![]() I guess I will have to try electrolysis. I got a box of Washing Soda, now I got to whop up a power supply. |
CAD it's looking great! To bad ya can't get another disc. I think you'll be happy with the soda method.
![]() Norton Rapid Strip abrasives at MSCdirect.com The link has both 4-1/2" and 7" diameters listed. http://www1.mscdirect.com/eCommerce/...on+rapid+strip Take notice the top two have 5/8-11 hubs while the bottom two have a 7/8" hole. The "match" looks to be MSC #: 06115893 , the second one down. Yes, you can set up a personal ( or business ) account and have them shipped directly to your house
You sure lay down a nice bead. What're you using to weld with?
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
| Thread Tools | |
| Display Modes | |
