Old 10-31-2009, 11:01 AM
TEET's Avatar
TEET TEET is offline
Default New (old) AG tires on my 127
Hi all,
Well...I finally picked up a pair of decent used Carlisle Power Trac AG tires with rims for either my 73 or 127. I decided to put them on my 127 to see how they looked, and I'm pretty happy with them, however they are 23 x 8.50 x12 and look to be mounted on wider rims. I guess this is fine, but it puts them at a bit wider stance than the stock rims and tires. I didn't measure the rims, but they look like the same ones on my 1211, as the valve stem is on the inside. My other thought was how small they look compared to the old good year 23 x 8.50 x 12 tires that were on it. Dimensionally they aren't as tall, and a tad narrower. Could this be from mounting them on wider rims, or do sizes fluctuate that much? Whatcha think? :biggrin2.gif:
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 10-31-2009, 11:14 AM
Merk Merk is offline
Here are the same tires on 7 inch wide rims:
Old 10-31-2009, 11:53 AM
TEET's Avatar
Thanks for the pic Merk! Those look great! My rims are definately wider than your 7" rims...I may end up swapping them over to the 7" rims on my 73.
Whats are you opinion about the tires in general? I know they are 2 ply, but for light usage, either snow plowing or just pulling a trailer, they should be ok..right?
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 10-31-2009, 12:25 PM
Your tires look great, Jeff! They will be fine, for what you want to do.
Old 10-31-2009, 01:02 PM
by TEET
Power Tracs give me great traction.
I have them on my 149 and my 100. Both go to plow days and my 149 is used in the witertime for snow removal. They are great tires. 2 ply is all you need. Anything over a 4 ply on a garden tractor is wasting your money.
Old 10-31-2009, 02:46 PM
TEET,
Tires look great You will be able to get a bite now
Old 10-31-2009, 03:13 PM
RPalmer's Avatar
RPalmer RPalmer is offline
They look teet. I can't believe you will have any load issues with them.
Old 10-31-2009, 03:16 PM
TEET's Avatar
Thanks Merk, ACecil, Diz and RPalmer! I'm happy with them so far, and I'm sure they will work great! I got a great deal on these in lightly used condition, but it seems like they are quite reasonably priced brand new! I may have to pick up a pair of 23 x 10.50 x 12 for my 1211 now
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 10-31-2009, 04:46 PM
TEET's Avatar
Originally Posted by Wild Bill View Post
Jeff, The sentence that I made red from your original post is a hint to why the tires 'look' different.
IH rims have never had the valve stems on the inside. You have JD, WH, etc rims, painted white. They will bolt onto a CC, but usually the backspacing is different...that is probably one reason, along with the rim being a different width between the beads.
Thanks for the interesting info wild bill! I never would have known....so now I have a 1211 and a 127 with non IH rims. What about CCC rims? I'm thinking the rims I just picked up with the ag's are from a later model tractor. The rims on the rear of my 1211 are the rims its had since it was new, the only reason I know is because my dad bought it new in 88'. I also have a pair of rims from a CCC 1204 that I parted out, and these are the same as my 1211 with the valve stems on the inside...hmm...interesting. I wonder what the reason was to have the stems on one side or the other?
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 10-31-2009, 05:10 PM
That's odd...I've owned a lot of CCC-built tractors, NONE of which had the valve stems on the inside. The CCC 8.5" wide wheels are identical to the ones used on the IH tractors, and were used until about 1997.
