Old 05-21-2012, 09:15 AM
dhlii dhlii is offline
Default 1860 Steering problems
i have an 1860. Both the splines and groves in the steering knuckle 703-1748 and 703-1884 the steering arm have worn down.
I can not get the bolt 710-3210 tight enough to make steering reliable without risking snapping it.
Apparently these parts are no longer available, so replacing them does nto appear to be an option.
I have had a sugestion that I drill through the arm into the knuckle and drive in a pin - but if that fails od damages things further I an even more SOL
I have considered replacing the bolt with an oversized bolt.
Any ideas ?
Any sources for these parts to do it right ?
Are there alternate parts that might work ?
Old 05-21-2012, 09:24 AM
Any ideas ?
Call or email Rich at Patton Acres. His link is at the top of every page.
Old 05-21-2012, 09:59 AM
Any ideas ?
I'd give this a try. http://www.devcon.com/products/produ...utty%20%28A%29
The splines on both the spindle and the arm would need to be cleaned, before you use this. Once it has cured tighten the clamp bolt and it should work.
