Old 05-22-2012, 10:15 PM
bmbigdaddy bmbigdaddy is offline
Default hydro rear getting hot
I mowed the other day and sprayed my 1210 off and seen steam coming off the rear. The fluid was a little low. Would that be the problem or could something else cause this ? Thanks for the help.
Old 05-22-2012, 10:30 PM
The cooling fins on the hydro pump need to be clean, and the fan needs to have all of its blades intact.
Old 05-22-2012, 10:45 PM
the fan is clean and in great shape i have not had this mower long and cleaned it all very good when i got it i have only used it twice
Old 05-23-2012, 12:38 AM
Ozcub's Avatar
Ozcub Ozcub is offline
If new it will probably have 10w/40 oil in it that may not be good enough for a hot climate
20w/50 is recommended for a hot climate
Old 05-23-2012, 06:12 AM
A 1210 uses Hytran, not either of those.
Old 05-23-2012, 07:03 AM
They do build some heat, it is not a good idea to spray cold water on anything hot, as they cool down suddenly among other things, they tend to suck water into the innards.
I would think this temp is typical.
Old 05-23-2012, 08:16 AM
Along with what Matt said do yourself a favor and pull the fender pan of and clean the top of the hydro and transmission. Kind of a PITA but it will last longer. If you have not changed the oil & filter that is also something you should do. 2 gals of Hytran and a NAPA 1410 filter. If the rear cover has never been off good idea to remove that and clean the goop out of the bottom of the housing.
Old 05-23-2012, 07:30 PM
I have took the fender pan off and cleaned every thing. I think I will take the rear cover off and clean it. Does anyone else sale Hytran besides the Cub dealer?
Old 05-23-2012, 07:35 PM
Originally Posted by bmbigdaddy View Post
does anyone else sale hytran besides the cub dealer?
TSC sells it!!
Old 05-23-2012, 07:44 PM
i have took the fender pan off and cleaned every thing but i think i will take the rear cover off and clean it and does anyone else sale hytran besides the cub dealer?
IH Case dealers sell Hy-Tran also.
