Old 05-31-2012, 10:17 PM
olmstead25 olmstead25 is offline
Default Tried out my #1 tiller
Well i finally got my drive belt to line up on my 1450 and i was able to get it to run the gear box for my tiller. but there is a catch. i have no Electric PTO. i have a live pulley on the front because i can not afford the $400 clutch. (PO left me with no parts to work with. just a shaft more or less) i used it this was all winter to throw snow making sure to be very careful( i have storys about that, and lessons learned as well) so when my engine is running my tiller is running.
Now for the second catch..... i have no sleeve hitch. that means the tiller rests on the ground.... always. Impossible to do you may say, au contraire. i blocked up the tiller, started the engine, slammed it forward, driving the tiller off the block onto the ground were it pushed me. right as i was comeing up to my "till zone" i go full throttle and start to slow it down to get the tines to dig in.. getting to the end of the row was interesting as well let me tell you.
Matthew 7:21“Not everyone who says to Me, ‘Lord, Lord,’ will enter the kingdom of heaven, but he who does the will of My Father who is in heaven will enter.
Old 05-31-2012, 10:18 PM
now for my real question. i want to get rid of the 1450 but only have originals other than that. can an original run my #1 tiller? i know i can get it to physicly bolt up but will it have the grunt i need to do any kind of tilling? has anyone tried or done this before?
Old 05-31-2012, 11:07 PM
You don't need the sleeve hitch just the rear lift with gear box and top casting. Got a pic of your set up?
Have you checked the air gap on the pto?
Old 05-31-2012, 11:12 PM
You could probably get a used PTO clutch for $50 or so. No need to buy a $400 new one...
Old 05-31-2012, 11:27 PM
i have no air gap on my PTO because i have no PTO. i have a pulley, bolted onto my output shaft! And my lifting method for putting it away is a ratchet strap.
I had absolutly no need to till my yard.. but not i have a need to plant some grass! or a garden i guess.
Old 06-01-2012, 06:28 AM
maddog784's Avatar
It sounds like you are missing the top casting, not the sleeve hitch.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 06-01-2012, 11:34 PM
your right. i do not have the casting. nor the sleeve hitch nor the lifting arm. i have none of it.
