Old 06-06-2012, 05:37 PM
nikster's Avatar
nikster nikster is offline
Default Round Thingies on the deck ?
I'm sure the round thingies serve a purpose. Since I changed the 48" cutting deck to accept the quick release so it will fit my under-carrage for my # 122 I noticed underneath that the 3 round thingies are TOTALLY SHOT.
I'm sure that there are NO replacement parts for this, and am thinking to rip them out since there is no SAVING the existing one's that exist . About 30% of its gone already & its barely hanging in there, holding on by some rust & all loose.
Any comments or- what to do?
Nik,
Old 06-06-2012, 05:47 PM
jkier's Avatar
jkier jkier is offline
Are you referring to the baffles?
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 06-06-2012, 06:57 PM
tractordude tractordude is offline
Ole, thems the B-O-L-T-S, they keep the heilcopter blades ON.
Old 06-06-2012, 07:47 PM
nikster's Avatar
Yes, now I know what they are called
Baffle s
Nik
Old 06-06-2012, 08:12 PM
David a Calkins David a Calkins is offline
Default round thingies on deck
i would replace them ,if you want the deck to work right
Old 06-06-2012, 09:01 PM
cmatthew's Avatar
cmatthew cmatthew is offline
rip those off and replace. you can get some metal flashing and cut and bend to fit. thats what i did. also you can either tack weld them in place or use small corner braces on the outside of the baffles with some bolts to hold them on. just have to do some drilling.
Old 06-06-2012, 09:41 PM
nikster's Avatar
Thanks, I read the post above in re; baffles.
That answers my question. Guess I'll rig up something to get new ones in place.
Nik,
Old 06-06-2012, 11:22 PM
Nik,
Nik, that's a pretty easy fix for ya and it will improve the cut.
Old 06-07-2012, 05:37 PM
Yup, they are called baffles, and every mower deck I've used had them missing and it still mows great. Not extremely necessary to have, unless you don't like a grass trail behind the tractor as all of it doesn't blow out to the side.
Old 06-07-2012, 07:22 PM
Donovan M.'s Avatar
my 38in and 42 in deck dont have them and they cut great.
Donovan:
62' Original-fenders
