Old 06-06-2012, 07:20 PM
cub71 cub71 is offline
Unhappy Deck pully keeps coming loose?
I got all of the new bearings put in my 38'' deck for my 71 and started to mow with it. After a few passes the pulley on the left hand side of the deck, non-discharge side, loosened up. I tightened it back down, but not to much because otherwise the pully won't turn and it did the same things again. It is the only one doing it and it makes no sense to me. Anyone have any ideas, I am finally going to get a chance to mow with my cub cadet for the first time in my life and all I get it setback after setback.....
Old 06-06-2012, 08:20 PM
David a Calkins David a Calkins is offline
Default deck pulley keeps coming loose
try some removable loc tight
Old 06-06-2012, 08:57 PM
Originally Posted by cub71 View Post
.......... I tightened it back down, but not to much because otherwise the pully won't turn ............
What is causing the lack of clearance? Are the new bearings seated to the correct depth?
Old 06-06-2012, 09:35 PM
when the nut that is on top of the pulley with the grease fitting in it is tightened, to much the pulley binds up.
Old 06-06-2012, 10:14 PM
You did recently take this spindle apart? There is a spacer attached on the bottom of the pulley.It is prolly worn.I had to replace mine on the 48 incher.
Up to 534 and counting...
Old 06-06-2012, 10:19 PM
Did you put a washer under the pulley instead of on top? Something is causing interference that wasn't an issue before.
Old 06-07-2012, 08:09 AM
I agree something is not right with that spindle. You're going to have to at least take the pulley off to find out why it is binding up.
Old 06-07-2012, 09:30 PM
underneath of my pulleys is where the bearings are there is no seal or anything. It is how the deck was so thats how I thought it was suppose to be.
Old 06-07-2012, 09:37 PM
Is your deck a cast iron end like mine on my 122?
Old 06-07-2012, 09:48 PM
Yes it is.
