Old 06-09-2012, 11:03 AM
fonty fonty is offline
Default Fab the hitch
It must not be real hard to do, I welded one up one Saturday!!??
Why not give it a try!!
CADplans,
I agree, but what I need are the dimensions especially for the lift bar and attaching hardware as shown in the picture I posted earlier (part # 3 & 4). Is the bar straight or does it have a bend in it on its way to the forward connection point.
I can guess at the rear cast portion dimensions and assume that the lower lift bar is 90 degrees from the implement attaching point. Should I assume that it is in fact 90 degrees? What is the distance between the center of the thru shaft and the center of the lift bar connection point?
Old 06-09-2012, 11:22 AM
I renamed this as your asking about the rear lift and not the sleeve hitch.
Old 06-09-2012, 01:06 PM
Default Renamed
Sounds good, anything that will help is much appreciated
Old 06-09-2012, 08:28 PM
bocephus1991's Avatar
Here is the bar measurement I got from a member here
Brian
Old 06-09-2012, 08:29 PM
here is another that has the other part you wanted
Brian
Old 06-10-2012, 02:10 AM
Thank you very much bocephus1991, I will get to work building these parts and send in a picture of the finished product when completed.
Now all I have left to do is get the dimensions of the tiller mule drive and I will be golden.
Old 06-10-2012, 12:25 PM
Donovan M.'s Avatar
you should make a 0 category hitch and i frogot to mention.
Donovan:
62' Original-fenders
Old 06-10-2018, 07:31 PM
Crossfire75 Crossfire75 is offline
What diameter rod is in the upper left corner of the picture? Building my own hitch and lift myself on a 129
