Old 06-24-2012, 07:48 PM
mrcubcadet's Avatar
Default 1512 Power Steering Conversion
Hey guys! Just got off the phone to Chris at Cub Cadet Classics..and looks like I will be buying the power steering unit off of his 2072!
Sorry Doug...I am a whippersnapper!
So, in the next month..I will probably be starting to put this thing on. My question is, how hard will this conversion be? Should be a bolt-up, since it all is the same in the front between a 1512 and 2072, shouldn't it? If anyone has pictures of this conversion, they would greatly be appreciated!
-105___ Tiller
Old 06-24-2012, 09:28 PM
mrcubcadet's Avatar
Forgot to add...Chris will be throwing in everything that is power steering related on the tractor. Including the spindles...
So, will I still need a different axle?
-105___ Tiller
Old 06-24-2012, 09:31 PM
No, I would use your current axle and spindles, but drill a new hole for the tie rod end that is the same distance from the pivot as on the SGT front axle. The spindles from an SGT will not fit a GT axle.
Old 06-24-2012, 09:35 PM
mrcubcadet's Avatar
Maybe he said spindle cap? Where the clevis attaches?
-105___ Tiller
Old 06-24-2012, 09:45 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
good deal, good buy too..
Doug
Original , 100 , 125 , 582
Old 06-24-2012, 09:56 PM
mrcubcadet's Avatar
Thanks, Doug!
I'm hoping to do everything this thing needs at once..while the engine is out. Drive-line rebuild, alternator/water pump belt, hydraulic o-rings, and now the power steering. Even thinking about adding one of XMV's hydraulic split kits.
-105___ Tiller
Old 06-24-2012, 11:22 PM
The spindle cap as you call it is integral to the spindle on a GT front axle, and splined to the spindle on an SGT.
I should have worded it this way: There are no interchangeable parts between a GT and an SGT front axle. They are completely different.
Old 06-25-2012, 07:34 AM
mrcubcadet's Avatar
Ok..So, I will have to make these spindles work.
And I won't have any issues with the cylinder/ram hitting the tire?
-105___ Tiller
Old 06-25-2012, 10:55 AM
inspectorudy's Avatar
When I did my conversion the ram hitting the tire wasn't even close to being an issue because the ram doesn't move, only the rod moves. The ram does move a little sideways as the wheels are turned to the left but it isn't that close. I also had two holes on the spindle arm which gave me a choice of turning radius. I ended up using the one closest to the wheel for stop to stop turning. I used the front axle from an 1862 and the spindle arm was not integral to the spindle but came off if it needed to be removed which I did several times to get the left/right travel centered. I do not know if an 1862 is a GT or a SGT. Once you get it done you will really enjoy the improvement. It would be interesting to know what PS cost the manufacturers. If it is less than $500/tractor it should be on every model that will use any kind of implement other than a mower deck.
1811 Hydro
Old 06-25-2012, 12:45 PM
mrcubcadet's Avatar
I looked at your thread on this.. There is a lot of valuable information!
My question is, why didn't you use your old axle? Was there no way to use the factory, 82 series axle?
-105___ Tiller
