#21
If I run a full tank of fuel I'm glad to get off the seat to stretch my legs.
#22
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
#23
I'm not trying to make anybody mad because I'm not but I am a little dumbfounded that some of you guys are scratching your head on why I'm doing my fuel tank conversion. I'm looking at it pretty simply
1. I would like to have more fuel capacity so I can mow my whole lawn without worrying about it running out of fuel when I'm mowing the hills around my pond. 2. I have the fuel tank and all the parts to do it. 3. I want to make my cub my own and not like most others. 4. I wanted to do something that no one else has done and have fun making it work. Sorry if I offend anyone but I just dont understand why my customization is getting bashed.
#24
I didn't seeing anyone bashing you, merely responding to your idea. I think it's going to be more problems than it's worth, with re-routing heavy cables from/to the SG etc, but it's your tractor.
John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
#25
Thanks for your comment, I have to get a wiring harness and rewire the whole tractor anyway so wiring is not going to be a problem. Plus I got the battery cable run to the front already. The only problem I'm seeing that will take a little time to make is that I'll have to modify the tank clamps to attach to the battery box. I am going to get a Y and connect the two fuel lines between the front tank and the carb so that won't be a problem. That the only things I'm seeing I'll have to do.
#26
Make sure your tank clears the center brace on the hood.Hope to see some pix of your tank modifications.
#27
#28
Another great benefit is you can escort those B-17's all the way to Berlin now.
![]() Just havin' a bit of fun... |
#29
This is going to be a neat project, Adam!
![]() If you need to fill up multiple times while mowing, then I think this is a great idea to fix that! I'm excited to see this when its done, and I think it is going to be pretty neat!
-105___ Tiller |
#30
![]() ![]() Quote:
| Thread Tools | |
| Display Modes | |
