Old 07-01-2012, 12:37 PM
That has a taper lock pulley on the crank end. Soak it good in PB. Remove the two bolts in the front and put them in the two opposite holes that are threaded and slowly tighten them. Don’t overdo it because it’s very easy to crack the cast iron, ask me how I know. You may need a little help with the fire wrench to heat the pulley and help expand it.
I have the drawing for the drive shaft adapter that bolts to the other end. If you need it PM me with your e-mail address and I will send it to you
Old 07-01-2012, 12:39 PM
Donovan M.'s Avatar
if you keep it like that. you could give it to me for my original.
Donovan:
62' Original-fenders
