I will probably replace the piston in my 1450. Can I use the old rod with new rod bearings and the new piston? If yes, what would be the torque? Anyone have a reasonable supplier for the rubber ISP mounts?
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
I would replace the rod also!
Other people have used moog and solid mounts but I have found the OEM rubber Iso's from Cub Cadet work the best! My 0.02!
Thanks for your advice!
All cleaned up. Figure on replacing the rod and piston.
Have your crank measured as well. |
I only have regular calipers, so if you think I need to buy some micrometers, let me know. Measurements were: rod journel- 1 & 1/2". Bore was 3 & 1/2". As far as I tell, these measurements are within stock specs. I was able to push the piston and rod out of the bore with very little effort. Carb is good.
I'm replacing: STD rod and piston Piston rings Head gasket Oil pan gasket I would like to replace all reed valve parts except the cover Carb gaskets, I have a spacer plate between carb & block All stock ignition parts to include a coil mounting bracket Rod that operates the points I'll lap the valves and adjust them and reset the timimg. Did I miss anything?
Measure the crankshaft rod journal in at least 2 places. I would not be suprised if it is out of round, and out of spec. You need to be able to measure to the precision of at least one thousandth of an inch (0.001") possibly to see it.
Cheers
Cub Cadet 129 48" deck - grass mowing 38" deck - backup deck 42" front blade |
You absolutely have to have micrometers to measure the bore and crank...calipers are not going to cut it.
Engine is rebuilt and ready to install. Great compression. Waiting on ISO mounts and modified engine cradle. I've been told to run the engine WOT for 20 minutes and retorque the head. Is this correct? I'm installing a magnetic oil pan plug and I'll change the oil when I retorque the head.
| Thread Tools | |
| Display Modes | |
