Old 08-12-2012, 09:01 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Default Brinly B-C 10 Refurbished
Getting the correct bolts set in the proper holes proved difficult. Next time the bolts will be labeled.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 08-12-2012, 09:08 PM
Excellent job on your plow!
Old 08-12-2012, 09:54 PM
PaulS's Avatar
PaulS PaulS is offline
Man that plow really cleaned up nice. Was that you that called me the other day. Msg was garbled.
Old 08-12-2012, 10:21 PM
The difference is amazing. Are you sure you didn't find one of those sets of pictures on the web? ( at least make the floor match in the pics)
Great job on the plow restoration
Old 08-13-2012, 01:21 PM
fleetlines's Avatar
Thanks Allen. As always, I take your kind words for encouragement on the next project.
This was rather easy but next time I'll label each and every bolt. They had different wear patters and since they fit in the right hole in 4 different positions, assembly wasn't too smooth.
The face ended up a little more pitted than I had originally thought it would be but it isn't bad. I painted it because I don't know when I'll ever be able to use it and didn't want it stored slathered with grease. I don't think I called - though I might have. There was an auction with lots of cubs but it was a little to far and I didn't get to go. I thought of asking you guys if you wanted to go with.
Thanks Jeff. I actually do a fair bit of stuff like this in a room in the house. It's laid out where I can. I just don't like to do the stinky or particularly dirty stuff inside but the rest can be a go. The "floor" is just a sheet of OSB so I don't hurt the epoxy concrete. :-) This just got dismantled and assembled inside - in the AC.
Old 08-13-2012, 01:48 PM
Anytime Curtis!
