Old 08-12-2012, 04:53 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Originally Posted by all4jpn View Post
Ok. So it seems the pump is shot. What is the noise that is being made when the lever is all the way up or down(see vid)
What model is the pump, are they rebuildable, and is there a manual?
Also what other cubs had the same pump. Thanks so much for the help
I have one on ebay right now that will work, it is a good pump I just decided ot part out the machine. http://www.ebay.com/itm/150876891983...84.m1555.l2649 You would have to reuse your check valves or buy some new ones seperatel. It's pretty easy tp swap them out. Rebuilding them is very expensive, I've heard anywhere between $600 and $900. Good luck
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-12-2012, 10:50 PM
Do some pressure testing to find out what is going on.
Old 08-13-2012, 09:19 AM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Does you lift work?
If not than your issue is in the charge pump area, no oil or filter blockage.
The charge pump is right behind the Rag Joint on the drive shaft. Its held to the trans by 2 bolts. If you remove it make sure you mark the cover to the block it has to go on the same way other wise it will not work.
You can also check the pump by removing the allen head screw between the relief valves, this is a test port for the pump. If you have a pressure gage that you can thread in to this port you would get 70-150 psi in neutral, 500-650 psi under load.
If you don't have a gage you can hook a hose up and see if any thing comes out into a jug with some force.
If your lift is working chance are the charge pump is in good shape. There is a regulator valve that controls the oil from the charge pump to the main pump of the trans. Its rare for this an issue but its the last thing before declaring the trans is shot. This valve is located on the right side of the trans (as you sit on the tractor) and right behind the right bolt that holds the charge pump on. It larger than a 9/16 bolt head. Not much to it just a spring and a ball again rare it would fail.
Old 08-13-2012, 09:45 AM
As found in the Service Manual....
Old 08-13-2012, 10:25 AM
Mike1450's Avatar
Thank Roland!
There is also a section in the manual that shows the charge pump removal.
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
I notice in the library that I did not see the service manual specific to the hydro, did I miss it?
Old 08-13-2012, 09:02 PM
David a Calkins David a Calkins is offline
Default 1650 won.t move
looking at the photo ,i see the spring has worn groves in the plate ,that will need to be welded up and refited it will cause more problems later
Old 08-18-2012, 12:13 AM
cmatthew's Avatar
cmatthew cmatthew is offline
in the manual it also states that the draw/cooling tube should be filled if you drained the fluid and refilled. its a chance that the pump isnt priming then. i shoved a flexible hose in mine with a large syringe attached to fill the tube as much as possible.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
