I picked up a Kohler carb kit for my K321 on my 147 at the local Cub Cadet dealer. The motor needed to have the choke pulled ever so slightly to run smooth, so I figured the carb needed to be gone through.
So I glanced at the kit, then pull the carb off and start taking it apart. My lack of attention has got me into a jam. I thought the brass thing in the kit was a main jet... So I was trying to remove the old jet from the carb using a flat blade screwdriver. Well, that didn't work, the screwdriver tip ended up slipping out of the slot and gouged the brass... Upon closer inspection, I saw that the kit contained a new seat, not a new main jet! Arrgh! Are these jets non-removable? I'm hoping I didn't just ruin this carb. I am tempted to try putting it back together with this jet but I don't know if it'll run right now. I saw this carb has a "30" stamped into the bore, I'm guessing it's for 30mm bore. Any insight would be appreciated! Thanks! |
Well I put 'er back together, and it runs like a champ! Thanks!!!
your best bet is to soak the carb for s few hours to overnight in carb cleaner (bought at local parts store) before attempting to remove. you then need a screw driver that fits near perfect and preferably good quality . hold carb firmly and apply the most downward pressure you can and turn . they usually come loose . if you screwed up the end on yours it should be fine as long as the hole is clear
I shot a little video doing the first cold start after the rebuild!
http://www.youtube.com/watch?v=qYH7qoBsYHU |
Oh, that's my '71 skylark, the "perpetual project car" LOL. Hasn't been on the road since '04, maybe next year!
EDIT : Here's another video from this morning, LOL. http://www.youtube.com/watch?v=k7KG6LInzFs |
LOPosse...OFF ROADING FOREVER!!
Glad I'm not the only one who would do something fun like that!I sure would have liked to see some pulling videos, though!! Camera problems? ![]() Rob
![]() It's so nice out.....I think I will leave it out! |
| Thread Tools | |
| Display Modes | |
