Old 11-14-2009, 11:00 PM
kdursus's Avatar
kdursus kdursus is offline
Default Rubber bushings
Okay, other than the one I'm showing here of course has anyone ever seen any rubber bushings like this? I've looked on McMaster Carr, gone to a local hardware store, and have done a pretty good web search. They're rubber vibration dampers that go under the seat on one of my tractors. I wanted to get an additional set of four for another tractor I have only to find that they're NLA from the current manufacture of the original tractor this one came from. The dimensions are 1 9/16" overall diameter (could have started out as 1 1/2" and flattened out) 7/16" thick (could have started out as 1/2" and flattened) and has a 3/8" diameter hole in the middle to except a 5/16" bolt. Probably 1 1/2" w. x 1/2" th. with 3/8" hole.
Old 11-15-2009, 10:11 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
How about some thick rubber grommets?
http://www.mcmaster.com/#rubber-grommets/=4ir8q8
I have 4 fairly thick (>1/2") rubber bushings off my old truck shock absorbers. If you're close enough in CO, I can give them to you. My zip is 80026. PM me if you're close.
If you're too far away, go to your local auto repair facility and ask if you can scrounge through their dead shock absorber pile. You want the front shocks with the stud.
Good Luck and hope this helps!
Jim
Old 11-16-2009, 08:38 PM
kdursus's Avatar
Jim,
Thank you for the help. I found a source for the bushings. I was told that the part I was looking for was NLA by the tractor manufacture but found out it subbed to a different number. Not sure what's up with that? Yeah, I tried McMaster Carr.
